My question es maybe a dummy question, but I need to know what causes the diferences in de DESCRIPTION system field between two instances of jira cloud. See atached files.
It is very likely that one instance is a newer instance. I have noted some differences with the newer instances. Sometimes these differences catch up as the older instances are updated but not always.
Hi Jack. Thanks!
I thought the cloud instances were all the same.
In the first case my client report a bug (that not occur allways, and I can not to reproduce in my instance).
ERROR Reported: The system field Description when is edited from the board, have a strange behaviur:
1. What is written automatically is erased
2. Autocomplete does not allow writing.
Do you have any idea about it?
Thanks in advance!
Register now
