Difference status between use in project and statistics
Evelien.Roze January 20, 2023
I have changed the statuses and created the workflow as below, but the statuses aren't corresponding to the statistics I want to use, not all are shown.
How can I change this?
Andy Heinzer
January 31, 2023
I believe the behavior described here is encompassed in this new bug report over in https://jira.atlassian.com/browse/JRACLOUD-80376
It appears that when using a team managed project, if you create a new issue type that has a different workflow, the two-dimensional gadget will not correctly display the statuses from both workflows within that project.  Sorry to report that at the moment, we do not have a clear workaround for this behavior.  I would recommend watching that bug ticket for updates to this.
Jack Brickey
Note - I have a single workflow in my TMP. Hopefully any fix will address for me too.
Jack Brickey
I don't think we need additional screenshots at this point. You mention "this project". Have you tried using filters Associated with other projects by chance? I'm really scratching my head here. @Nic Brough -Adaptavist- any further ideas?
Evelien.Roze January 27, 2023
I have set-up a new testproject and added some testdata, and I have the same issue.
When I have tried to create to gadget with a filter of a project of someone else within the company, I don't have the issue.
So I don't know if it might be a setting within my projects that is wrong.
I'm working in a Software Project - Team-managed project. (I can't set-up a company-managed project due to rights within our company.)
Jack Brickey
First, I don't no how I got us set up on a different thread here. Obviously I clicked the wrong button. Which is something I preach against. :-(
Second, I don't understand this statement - "...with a filter of a project of someone else within the company, I don't have the issue.". Do you mean to say if you use a filter created by someone else, you do not have the issue? If so I would be really interested and having this other person create the exact same filter that you have and use the 2D gadget.
Third, and most importantly (?) I have been ignoring all along TMP versus CMP here. I don't have a TMP with a lot of statuses but will set one up and test. Do you happen to have access to an existing CMP project with more than four statuses that you could create a filter for and test?
Jack Brickey
@Evelien.Roze  & @Nic Brough -Adaptavist- , this seems to be a bug to me.
Here is what I did:
  • Created a TMP project with six statuses
  • Created sufficient issues and place them into varying statuses so that I could better analyze the results in a pie chart as well as a two dimensional statistics
  • I added a pie chart and 2D gadget to my dashboard using the same filter. On the 2D I placed Status on the X and Type on the Y.
Here, is what I discovered.
  • Only four of the six statuses are displayed.
  • On the 2D table it shows a total of 5 issues in the "In test" status. However, there are only 2 issues in that status. Interestingly enough, if I click on the 5 there are only 2 issues displayed.
  • It appears that in the 2D chart it is adding in the other missing statuses. This is illustrated in the yellow highlighted Numbers.
Evelien.Roze January 29, 2023
@Jack Brickey
Indeed, this is the issue I have.
Jack Brickey
Can you report to Atlassian support
Evelien.Roze January 30, 2023
@Jack Brickey
I apparently don't have the rights within our company to create a ticket. I'll have a look who can report this.
Jack Brickey
Me either :( but have pinged colleagues in my Leader Community for an assist.
Jack Brickey
Hi @Evelien.Roze , welcome to the community.
Would you mind sharing the filter details associated with your two dimensional gadget? You can do this by editing the dashboard configuring your gadget. Once you know what the filter name is you can look under filters and share the JQL that defines the issues you are including in the gadget.
Jack Brickey
Also I assumed this workflow has been published. Can you please verify this? One quick way to understand is to View an issue and clicking on the status field you should be able to view the workflow there is being used. I just want to make sure that all of the statuses are indeed associated with the issue.
Hi @Jack Brickey ,
These are the details of my statistic:
This is my filter:
In my filter overview, I can see the other statuses:
Jack Brickey
hmmm, I am missing something here. Everything seems in order and yet some statuses are missing. My theory was going to be that you didn't have any issue types that were in the missing statuses. The two dimensional gadget doesn't display an entry for this empty-set scenario, if memory serves. However, your last Image shows a Story with the status of In Test which is not displayed in your statistics.
Just for grins, could you create another two-dimensional gadget using the same filter and flip the X andY axis?
Evelien.Roze January 20, 2023 edited
Yes, I have created mutiple gadgets with this or another filter within the same project and they all won't show the missing status.
It's a mystery to me why he does show 'Assigned to IO' and not the other ones I have created as extra's.
Evelien.Roze January 23, 2023 edited
@Jack Brickey
Would you know a solution or can someone else assist?
Addition:
Ex. I delete 'Assigned to iO' out of the filter and only select 'Todo', 'In progress', 'Done' and 'Translations'.
Then I'm able to see Translations, but it seems when I select all status, there is a limit to only show 4. I can't seem to change this anywhere.image.png
When I use a PieChart, it is showing all status:
Jack Brickey
Hi @Evelien.Roze ,
It definitely is not a limitation of the gadget. At least as far as the number statistics in the X & y-axis. Proof of this below.
I wonder if you could try completely different filter for your two dimensional gadget just as a test.
  1. For the filter select "All projects"
  2. X = statuses
  3. Y = issue type
If that works then edit then reconfigure the gadget so that the filter equals "WB" project.
Results?
Evelien.Roze January 24, 2023 edited
Hi @Jack Brickey
I can't seem to select all projects using this statistic.
I have found a solution for the Issue statistics, when I select
  • Sort by = Total --> they all show
  • Sort by = natural --> only 4 show
But the above is no solution for the Two Dimensional Filter. The statistics below are all based on the same project, but give a different result.
And the same when I switch X and Y:
Jack Brickey
Hi @Evelien.Roze , so natural/total works fine for me in both cases. I wonder if you have some addon that is causing a conflict here? At this point it might be worth having Atlassian support have a look. I'm scratching my head here.
January 24, 2023
This looks really odd to me, but I want to ask you to do two more things if you have time.
In the config of the 2d gadget, change the "number of results" to 50 (I think that's the maximum.  Similarly for the other gadgets you're trying (if they have the option)
A longer one, and only to help us here to debug it - choose a filter that causes the problem, but returns only a short data set.  Screenshot the dashboard gadget showing the problem for us (we'll assume the config is the same), and then go run the filter, and show us the results from the issue navigator (text in a table is fine if you don't want to screenshot).  We only need three columns - issue key, issue type and status.
Evelien.Roze January 25, 2023
I have done the changes as in your first request, but no change here:
For your second question, is this what you need? It's based on the same details of my previous screens:
Issue TypeKeyPriorityStatus
BugWB-119MediumAssigned to iO
BugWB-118MediumAssigned to iO
TaskWB-117MediumTo Do
TaskWB-116MediumTo Do
StoryWB-115MediumIn Progress
TaskWB-114MediumTo Do
StoryWB-113MediumTo Do
BugWB-112MediumTo Do
BugWB-111MediumIn Progress
TaskWB-110MediumTo Do
BugWB-109MediumTo Do
BugWB-108MediumTo Do
BugWB-107MediumTo Do
EpicWB-105MediumIn Progress
BugWB-104MediumTo Do
BugWB-103HighTo Do
BugWB-102MediumON HOLD
StoryWB-100MediumTo Do
BugWB-99LowAssigned to iO
TaskWB-98MediumAssigned to iO
TaskWB-96MediumAssigned to iO
TaskWB-95MediumAssigned to iO
TaskWB-94MediumAssigned to iO
TaskWB-93MediumAssigned to iO
BugWB-92MediumAssigned to iO
StoryWB-91MediumAssigned to iO
TaskWB-90MediumON HOLD
BugWB-89MediumTo Do
StoryWB-88MediumTo Do
TaskWB-87MediumAssigned to iO
BugWB-86MediumDone
TaskWB-85MediumON HOLD
BugWB-83MediumAssigned to iO
BugWB-82MediumON HOLD
TaskWB-81MediumAssigned to iO
TaskWB-80MediumAssigned to iO
TaskWB-79MediumAssigned to iO
TaskWB-78MediumAssigned to iO
TaskWB-75MediumTo Do
StoryWB-74MediumTo Do
StoryWB-73MediumTo Do
BugWB-72HighTo Do
EpicWB-71MediumIn Progress
BugWB-70MediumAssigned to iO
BugWB-69MediumAssigned to iO
BugWB-68MediumAssigned to iO
BugWB-67MediumDone
TaskWB-66MediumAssigned to iO
BugWB-65MediumDone
TaskWB-64MediumAssigned to iO
TaskWB-63MediumAssigned to iO
TaskWB-62MediumAssigned to iO
TaskWB-61MediumON HOLD
StoryWB-60MediumTo Do
StoryWB-59MediumTo Do
BugWB-58MediumDone
TaskWB-56MediumAssigned to iO
BugWB-54HighTo Do
TaskWB-52MediumTo Do
TaskWB-51MediumTo Do
StoryWB-50MediumTo Do
StoryWB-49MediumIn Progress
EpicWB-48MediumIn Progress
EpicWB-47MediumTo Do
EpicWB-45MediumIn Progress
EpicWB-44MediumIn Progress
EpicWB-43MediumIn Progress
TaskWB-42MediumTo Do
TaskWB-41MediumTo Do
StoryWB-40MediumTo Do
TaskWB-37MediumTo Do
StoryWB-36MediumTo Do
EpicWB-35MediumTo Do
StoryWB-34MediumIn Progress
BugWB-33HighTo Do
StoryWB-32MediumIn Progress
BugWB-31LowAssigned to iO
TaskWB-27MediumTo Do
StoryWB-26MediumTo Do
TaskWB-25MediumIn Progress
StoryWB-24MediumIn Progress
TaskWB-21MediumTranslation
StoryWB-20MediumIn Progress
TaskWB-17MediumTranslation
TaskWB-14MediumIn Progress
StoryWB-13MediumIn Progress
TaskWB-6MediumDone
TaskWB-5MediumDone
TaskWB-4MediumDone
StoryWB-3MediumIn Progress
EpicWB-2MediumIn Progress
StoryWB-1MediumIn Progress
January 25, 2023
Fantastic, thank you!
(Well, not fantastic, because it doesn't show us the problem)
One last step - was that last table generated by clicking "Newsletter - Epic" under the charts?  What is the filter defined behind "Newsletter - Epic"?
I doubt we will see anything wrong, but this is all stuff Atlassian are likely to ask if we can get them on to it.
Jack Brickey
Or is the filter Website Overview? Are we testing with different filters here?
The latest ones I have uploaded are all based on the filter 'Website Overview', but I have the issue with all the filters I have set-up in this project.
Do you want the screenshots for filter Newsletter-Epic?
Learn more
