Different workflow for epics and tasks in Jira next gen
JAKE January 28, 2021
Hi, I would like to define a separate workflow for the epics in my project that is different to the workflow of tasks and stories. I found hints that it is possible in Jira in general but could not manage to do it in my environment --> Jira Cloud / next gen project.
Any help is welcome!
Thank you!
Eoin
August 25, 2021
This is available in Team managed Projects as of August 2021 :)
Jack Pfeiffer
June 29, 2022
Do you have a link that shows how to do this?
Like • 2 people like this
Eoin
January 31, 2021
@JAKE @Daniel Ebers @Pramodh M this is the feature suggestion to follow for having a dedicated workflow for epics... https://jira.atlassian.com/browse/JSWCLOUD-17434
We have a team actively working on it!
Eoin
Product manager
Pramodh M
Thank you @Eoin for the Support ticket notice. I will upvote.
Pramodh
JAKE January 31, 2021
Thanks @Eoin ! Looking forward to it!
Joseph Cohen
@Eoin  do you know if there's any update on this matter?
Adhib R
August 25, 2021
great. any update on this @Eoin ?
Eoin
August 25, 2021
It's just been made available! Let me know if you have any problems :)
Syed Haseeb Ali
October 8, 2021
Can different workflows be defined for different Epics of a same Project?
Reason for this Feature: As each Epic can have a unique Lifecycle/Workflow. So in order to successfully manage all Epics of a Project we need this Feature.
Pramodh M
Hi @JAKE
A separate workflow is not available for each issue type in Next-Gen Projects
All the issue types have a single workflow here.
Please follow the documentation here for more reference
https://support.atlassian.com/jira-software-cloud/docs/manage-how-work-flows-in-your-next-gen-project/
Pramodh
Daniel Ebers
January 29, 2021
@JAKE
There is a open Sub-Task with the idea of providing the option to create workflow schemes in next-gen projects:
https://jira.atlassian.com/browse/JSWCLOUD-19019
You could watch it's progress - unfortunately it is not directly visible from there when action is taken upon it.
