Hi I have an issue type called problem on Project X which has certain type of workflow applied to it.
I have created a test project and have the same issue type problem however want to assign it a different workflow without it affecting Project x.
Can i do this?
Regards
Neil
Yes, this is done by creating a new Workflow Scheme for the new project. See here:
https://confluence.atlassian.com/adminjiracloud/configuring-workflow-schemes-776636598.html
You need to define your new workflow, then create a new Workflow Scheme which includes the new workflow against the issue type in question. Then assign the Workflow Scheme to the new project.
