The disable option checkbox appear after several seconds. When it does the first time, we try to check it and it disappears instead of disable async poker on the project. After that it appears again and we can check it normally.
There are several errors on the console when we try to check the disable option and when the page loads.
You may want to email the vendor directly for this question. Here is their support information on the marketplace pages:
Best regards,
I'm with Async Poker.
I accidentally found this topic. We do not get notified of any topics from the forum related to the application. Please always tag me or write us at support@doasync.com
The issue was fixed.
Best,
Anton
Read the story
