I have created a new workflow state 'Archived' -> All with properties jira.permission = false and jira.editable = false. It does the work of locking the issue down at the end of the quarter using bulk update which is my goal.
But in my workflow there is also a state that says 'In Dev -> All, and even after ARCHVING the issue the button to transition the issue is available on the record. Is there a way to disable the button once the state is set to 'Archived'
it can be achieved through Script Runner plugin
you can disable "In Dev" transition from "Archived" though it is All transition
Steps:
1. Add Script runner Condition (to In Dev transition)
2. Choose "Allows the transition if this query matches a JQL query"
3. in query "Status != Archived"
Leo
Save your spot
