Disable comment auto collapse in JIRA not working?
jira.comment.collapsing.minimum.hidden
"The minimum number of comments needing to be hidden for comment collapsing to occur. 0 means there will be no comment collapsing."
I set it to 0 and comments are still collapsing.
Jira Cloud
Hi @ian.johnsen
This setting only works on the classic issue view currently - I assume you are using the new issue view?
You can check this in the classic view:
There is a suggested enhancement for this - I would suggest voting for/following JRACLOUD-74680
Ste
Register now
