Display a field on panel.
Tien Nguyen December 1, 2021
Only when I click the Actions button, I could see the Log work. I would like to show the Log work on the panel, not the Actions. How could I do that?  1111111111111111111111111.png
Magdalena Zhisheva
December 1, 2021
Hi @Tien Nguyen ,
Can you try to scroll down at the activity section? There you will be a drop-down list, where comments is selected by default. In this drop-down list you will be able to select the Work Log option.
Let me know if this works for you!
Greetings,
Magdalena Zhisheva
Do you mean this part?
I would love to see the Time tracking like this picture on the panel after loging work. Does it belong to Log work or an other field? @Magdalena Zhisheva
Magdalena Zhisheva
December 1, 2021
Hi @Tien Nguyen ,
Do you want to see it like this:
In the right panel?
@Magdalena Zhisheva I've got a misunderstanding between Time tracking and Log work. Now I've added them. Thank you so much for your time!
Magdalena Zhisheva
December 1, 2021
@Tien Nguyen I am glad you solved your question. If my post was helpful, mark it as Accepted solutions, so you can help others who may have the same difficulties.
Like • Tien Nguyen likes this
Register now
