I would like the priority of a sub-task to display in the one-line summary that appears on the parent issue screen. I've seen earlier questions which suggest that you can edit this by going to General Configuration -> Advanced Settings -> jira.table.cols.subtasks. But the version of JIRA I'm using doesn't seem to have this option so I wondered if the method for configuring this had changed in the latest version?
Hi Bryony,
Only Atlassian Support can edit "Advanced Settings" on JIRA Cloud. You can create a request on support.atlassian.com for further assistance.
Thanks and regards,
Paula Silveira
Hi Paula, Thanks for your reply, that explains it. Does this mean that I would be able to change it myself if I were using the server version of JIRA? Bryony
