Display related issues on other issue
Yaniv L
I have an issuetype named Capability, the Capability screen has only Summary to create values (screenshot A).
I have a Single Issue Picker, located on other issuetype (HLR) and reading values from the Capabilities list (screenshot B).
The HLR issuetype shows the chosen capability (screenshot C).
However when I'm viewing the Capability issue, I can't see the linked HLR (screenshot D).
What do I need to do so that the Capability issuetype will show all linked HLRs?
Evgenii
June 8, 2023 edited
You need to link issues, then you'll see all related HLRs in Capability.
But you are using custom field with selection. Issue in Custom field is not Linked issue.
Yaniv L
Can you point what is required to do/how?
Evgenii
June 8, 2023 edited
Sure, you can look, how to link issues, here.
https://support.atlassian.com/jira-service-management-cloud/docs/link-subtasks-issues-and-pages-from-the-new-issue-view/
Sorry, can't make example screenshots by myself, I am using DC version of Jira.
Yaniv L
Thank, I know this option but the user can select multiple values / other non-related using it.
Not what I'm looking for )-:
Evgenii
June 8, 2023 edited
Try to check, is it possible with Jira Automation to get value from field and add it as Linked Issue. Maybe it will help. Weird variant, but if it works... )
Yaniv L
@Piotr Zadrożny _Eyzee - I found you managed to solved something close to my issue.
(https://community.atlassian.com/t5/Jira-questions/Update-Linked-issues-by-automation-rule/qaq-p/1996757)
Can you advise?
Is there an option for such automation? Other solution?
Thanks!!
FREE
