Does the API token we create in JIRA expires? Or is there a count of times that we can call the JIRA REST API via the specific toke? Also is there a JIRA REST API call to create a API token?
The API token does not expire. However you can manually revoke a token.
And there is no API endpoint to create a new token.
Hi @marc -Collabello--Phase Locked-
Thank you for the answer. But is there a way to generate a token within my application, pass it to the JIRA server, save it as my API token, and then call JIRA REST API calls using it?
