Does Jira cloud provides colour coded custom field.
We want to create a issue type in which we want the severity to be defined with colour.
Red - high
Amber - medium
Green - low
Hi @kavita.desai and welcome,
Unfortunately single select fields do not support color customization.
hi @Alex Koxaras _Relational_ , thanks for responding.
Is there any other way to get this done. We want to get this on jira dashboard to represent RAG status.
Is it possible to add RAG custom field ?
I suppose that can be done in jira server.
You can add to your card a color, via your board:
And then you'll have colors:
hi @Alex Koxaras , thanks this helps. But does not resolve the issue completely.
So when I actually create a dashboard and list down the risks, it does not show colour code.
Can anything be done for it.
No, of course it doesn't show any colors. The colors are solely for the cards on your board, and not for the dashboard. You can try to search in the marketplace for an app.
Is there a way to see the entire card with color and not only a line, like in https://marketplace.atlassian.com/apps/1219454/color-cards-for-jira?tab=overview&hosting=datacenter
hi @Alex Koxaras _Relational_ , thanks this helps. But does not resolve the issue completely.
