Does Jira integrate with Appium?
Chandrasekar
May 24, 2016
Wanted to know whether we can integrate JIRA with Appium, during continuous integration if functional tests are triggered in Appium, a defect should be created in JIRA if any test case fails.
Does JIRA provides any API or plugins to integrate with Appium?
Nic Brough -Adaptavist-
May 24, 2016
I assume you've checked the marketplace for add-ons and found none?
If that's true, then you'll need to have a look at a bit of coding - if you can get Appium to make REST calls to JIRA, then you can easily do this sort of thing - JIRA's REST interface allows for creation and updates of issues remotely.
Robert Massaioli (Atlassian)
June 4, 2016
Deleted user April 18, 2019
Hi !
Appium is only a framework wich can use like interface within your IDE.
Do you refer to create case test with appium, Eclipe and Jira?.
check this out:
https://www.youtube.com/watch?v=Eyrm7zLjyPg
Ariel.
Chandrasekar
May 24, 2016
Thanks Nic...
Register now
