Hi
according to
archived versions should be hidden in the JIRA roadmap/plan tool.
In version Jira v9.12.7 also issues/features with released FixVersions are hidden, which limits the transparency of the status of initiatives.
Is the issue fixed in a version? If not is it planned to be fixed?
Regards
André
This can be if the issues in the version don't have the field fix version set or the screen used on the issue is missing the fix version field
This is also stated in https://confluence.atlassian.com/jirasoftwareserver0912/troubleshoot-missing-issues-in-advanced-roadmaps-1346049317.html
When I change the FixVersion from a released version to an unreleased version the issue appears. So I doubt its the screen configuration.
It seems that the roadmap hides issues with released versions. Is there a version with a fix?
The problem was not that released FixVersions are always hidden. But the problem was that released version were excluded during the creation of the plan. It took me a while to find this and include the release again in the plan.
Hi @Andre.Seharsch , how did include these missing release back into plans
Plan configuration -> Exclusion rules -> Press "View releases" opens a window with all excluded release. In this window you can include the release again to the plan.
