Due Date Automation based on status change
kalaimani
Hello
There are four statuses in my task workflow: open, in progress, waiting for confirmation, and done.For this reason, we have to set the default due dates to Open (1 day), In progress (5 days), Waiting for confirmation (2 days), and Done (one day).
For example, the issue's open status and one-day due date were set at the time it was created [23-11-2023].The due date is extended by five days if I change it from Open to In Progress, and I also need to set up other statuses.How should I set up Jira Cloud?
Ste Wright
November 23, 2023
Hi @kalaimani
This will be possible, but can I confirm some queries about the logic?
  • I assume there's an Automation Rule or Post Function that sets the initial due date when the issue is created - is this always the case?
  • What is a due date has been removed - how should the rule handle this?
  • Can a user skip a status (eg. go Open > Waiting for Confirmation)?
    • If yes, what should happen here given the "In Progress" +5 is missed?
Ste
kalaimani
  • Yeah Ok. It works in Post Function also?
  • Yes that is my question
  • Yes,If the status changes to a new status, the due date must be extended based on my days.
Ste Wright
November 23, 2023
Hi @kalaimani
No need to accept the answer until you have the response you need :)
You've not directly answered my questions - it'd be good to get these responses. Otherwise the rule will be possible to build, but I anticipate it'll have flaws in its logic.
Another question is:
  • Can a user move back a status? If yes, what should happen in that scenario (eg. In Progress > Open)
Ste
kalaimani
  • No, the workflow is only Open->In Progress->Waiting for Confirmation->done.So the user will not come back.
  • If the issue was created Open [23-11-2023] and the status was moved to In progress the Due date needs to automatically set Business days[30-11-2023] and In progress to Waiting for confirmation [04-12-2023].Hope now its cleared.
Ste Wright
November 23, 2023
Hi @kalaimani
Great! In your case, you can actually manage both rules (set initial due date and set status-based due dates) in the one rule - it will look like this:
  • Trigger: Multiple Issue Events
    • Events = Issue Transitioned, Issue Created
  • Condition: IF Block...
    • IF...
      • Sub-Condition: Issue Fields Condition
        • Field = Status
        • Condition = equals
        • Value = Open
      • Sub-Action: Edit Issue
        • Field = Due Date
          • Value = {{now.plusBusinessDays(1)}}
    • ELSE-IF...
        • Field = Status
        • Value = In Progress
        • Field = Due Date
          • Value = {{issue.Due date.plusBusinessDays(5)}}
    • ELSE-IF...
        • Field = Status
        • Value = Waiting for Confirmation
        • Field = Due Date
          • Value = {{issue.Due date.plusBusinessDays(2)}}
    • ELSE-IF...
        • Field = Status
        • Value = Done
        • Field = Due Date
          • Value = {{issue.Due date.plusBusinessDays(1)}}
A few notes...
  • I'd consider if this is needed on the transition to Done - isn't the issue complete at that point?
  • This rule uses multiple date and time smart values, see how those work on this help page
Let us know if this works for you!
Ste
kalaimani
Hi @Ste Wright
Yes, it is what I needed, and it worked. Thank you!
  • Suppose if one status like Waiting for confirmation there was no time limit so what should we do ?
Like • Ste Wright likes this
kalaimani
Got It .{{issue.Due date.plusBusinessDays()}} the Due date come now None.
Ste Wright
November 23, 2023
Hi @kalaimani
Glad it's working!
You could also just leave the field empty in the rule, and that counts as NULL.
Ste
FREE
atlassian, loom, AI, meeting recording, community
[NEW] Record your meetings with Loom
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
Learn more
