Hello All
I am looking for some assistance. I cannot find Due Date field in my create or editing of issues. The field does also not show within my Show Fields on the create screen. I can see Due Date when I go into the Project Settings > Issues > Fields it is visible and it is present in both the Create and Edit/View screen. I am unable to check within the Custom Fields settings as it does not show as I believe it is set by Jira.
What is more confusing, but might be helpful is that other users are able to see this field. But I cannot.
This may be something blindingly obvious that I am missing but any help would be appreciated.
Kind Regards
Steven
@Steven Lloyd if other users are able to see it but you can't then it means you don't have Schedule Issues permission
To fix this your admin needs to grant this permission to you:
