EazyBI MDX - How to display certain tasks
Onur Cevik
Hey!
I´m trying eazyBI and I want to have access of certain tasks to display them. Does someone know how to do it?
Ilze Leite-Apine - eazyBI
Hi
I am Ilze from eazyBI support.
If you want to display tasks in the report row, select Issue dimension in the report rows, and use Search and bookmark option to find the needed task, and then select it for the report:
Or, if you want to display the list of issue keys in the report cell, you may create a measure (un Measures) using function Generate()https://docs.eazybi.com/eazybi/analyze-and-visualize/calculated-measures-and-members/mdx-function-reference/generate
Look at the example in eazyBI community how to display the list of issue keys within a selected component: https://community.eazybi.com/t/generating-a-comma-separated-list-of-issues-for-a-component/10163
Feel free to contact us to support@eazybi.com for further assistance!
Ilze, eazyBI support
Onur Cevik
Hey @Ilze Leite-Apine - eazyBI
Thanks for answering. In the picture below you can see my issue. How could it work? I´m don´t have knowledge in mdx thats why I can not solve it. Epic Name is displayed incolumn. How to do with Task?Screenshot 2023-03-16 105922.png
Thank you for the screenshot!
You may want to import the issue summary as a property (e.g. Issue Summary), and then you can display it in the report as a column for any issue type.
There is a thread where is described how to get the summary imported as a property, using JavaScript calculated custom field: https://community.eazybi.com/t/get-summary-value/4028/2
Best,
Ilze
Like Onur Cevik likes this
Onur Cevik
Hey @Ilze Leite-Apine - eazyBI ,
Thanks. I have tried to follow the steps in this topic https://community.eazybi.com/t/sort-on-a-dimension/3771 but the JavaScirpt-Code did not work. Can you help me? Thanks in advance!
Onur Cevik
@Ilze Leite-Apine - eazyBIIt has worked. Thanks!
Onur Cevik
Another question. My Code seems to be wrong. Can you take a brief look on my code. Thanks! If my date called "Fälligkeitsdatum" ist 10 days before its date and 1 day before itself, my function should return 2.
IIF(
      DateBetween([Issue].CurrentMember.GetDate('Fälligkeitsdatum'),
      DateAdd('d', -10, [Issue].CurrentMember.GetDate('Fälligkeitsdatum')),
      DateAdd('d', -1, [Issue].CurrentMember.GetDate('Fälligkeitsdatum'))),
     "2",
Oskars Laganovskis
March 23, 2023
Hey @Onur Cevik ,
You are right - your given code has a flaw.
This will always return blank as no date can be between its previous day and ten days before itself.
Your expression refers to the same value in all references to "Fälligkeitsdatum".
Please consider what dates you want to compare. Do you really need the same field on all lines? Could it be that the first line should refer to a different field?
Oskars / eazyBI support
Onur Cevik
Hey @Oskars Laganovskis ,
Thanks for answering. I have solved it. It works now.
seo weboption March 16, 2023
A system administrator can search all users, datauptime. see accounts that they own ... If you see that some user is regularly having problems with entering correct MDX .
Learn more
