I took over a project and someone already set up default assignees for certain component types:
Hi @Filip Zafran this document should explain everything you need to know to overcome this small bump :)
Default Assignee
Hi thanks, but I do not have, not can I find, the 'Component' option.
However, some compenets seems to be set and I can not find a way to change them
I don't know what your setup is as far as permissions are concerned.
Check your Role and the permissions associated to it.
Go into Project Settings then Roles you may have to up your permission level or have someone else who can do it.
There's also a link to the components in the project settings.
