Hi, I don't seem to be able to edit or delete Work Log entries on iPad, which is where I do most of my Jira-fu. I do have permissions because the options are present on desktop.
Either I'm being blind, or this is a glaring oversight in the iOS/iPadOS app. Can anyone help?
You are not blind. The app does not currently support that it seems. You may wish to provide feedback to Atlassian.
2 years later, Atlassian proves to be caring less than 0 about this issue...
You might check JAC (Jira.atlassian.com) for the existence of a ticket or contact support.
