So, I have created a Custom field in Forms(enter Forms->select template->create new field), I did not create it on section Issues->custom fields, it doesnt even appear there, the thing is I can't find a way to edit the options of this drop down custom field in Forms, I can't deleated from the right panel and I can't then create a new one with the options needed. Help!
sure, I am using a template as is and just created a custom field in there here is the screen and in red the custom field i created only in that forms section.
using the field requires you to drag it to the form, to remove it, use the option "Manage your from fields"
When clicking on manage your form fields we only have a poor explanation of Editing in the form or making them required, nothing about deleating the field or adding options to a drop down or even take options out. I need to delete that field or add options to it.
Hello @Leslie Silva,
Thanks for your patience and providing screenshots.
In your last screenshot, can you confirm that your end goal is to delete the 'System' field from the right panel, so that it is no longer visible and selectable for the form?
On selecting the field "system", I expect you created this, or was it already there?
It should open a side menu to add the options or edit the title.
If it was already there it's a system field that you can't edit and you can't delete it.
Example on my side, created field Test.
