Enable capacity planning in Advanced Roadmaps
Moti Stein April 26, 2022
I read few docs about how to work with capacity using plan/roadmap but I can't see plans menu in Jira on the main top bar, and not any option of plan in the roadmap.
I tried to add the team field to issue field but then I can't choose my team, I get text of:
"plan specific teams can only be selected through a plan" - but I have no plan
How can I enable it?
Nataliya Vasyliv_Reliex_
Hi @Moti Stein
If you are looking for a capacity planner, as an alternative to Advanced Roadmaps, I would recommend a resource planning plugin ActivityTimeline.
ActivityTimeline is a scalable planning dashboard with a cross-project view for shared resources, multiple resource reports, and complex timesheets, to assist in planning. The system provides clear visibility of your resources’ activities & utilization for individual users and even for the teams.
You can take a trial or we can provide a demo session to see all features.
Nataliya, ActivityTimeline Team.
Robert Wen_Cprime_
Moti:
Are you on the Premium tier of Jira Software?  Advanced Roadmaps is bundled with Premium and above.
How can I check that?
Robert Wen_Cprime_
If you're an organization admin or site admin, go to https://admin.atlassian.com
Find the site in question.  Click on the more actions (the three dots) and then select View Billing
The billing page will show the products for that site and what biling tier.. Here's an example from one of my demo sites.
I pay for standard plan.
Can't I use the capacity? Is there any addon to handle the capacity?
Robert Wen_Cprime_
So, because you're on the Standard plan, you won't have Advanced Roadmaps (and its capacity planning feature) available to you.
Here's a listing of Marketplace apps that might help you with capacity planning.
https://marketplace.atlassian.com/search?query=capacity
Hope this helps!
Learn more
