Enable/disable external links share for Jira
Dana.Harel
Hi, is there a way to enable/disable external links share for Jira?
We would like the link sharing to be enabled by default with no option to check the checkbox manually.
Danielle Green
What you have is not native Jira functionality, but an app called External Share for Jira
https://marketplace.atlassian.com/apps/1220441/external-share-for-jira?tab=overview&hosting=cloud
I'd suggest contacting the vendor Old Street Solutions, or disabling the app if you don't want to use it.
