I want to create an Epic for a business requirement that impacts multiple projects.
Each project needs stories linked to this Epic.
Is this possible to do?
Thanks.
Hi Cathy,
Yes, Epics can be linked to issues across multiple projects no matter what project the Epic was created against.
Hi John,
Our requirement is also exactly same but with the help of either any app integrated in JIRA or via Rest API's. is there a way to do so since creating dependent tickets on epic is so time consuming that we are looking to automate the same.
Appreciate your response.
Thanks in advance,
Shravani Pandarmish.
Hi Shravani - Can you create a new question for the community for this? I will get a lot more attention that way. I will answer there also. But the quick answer is yes, automation for Jira can do that for you.
Here's some information to get you started:
There are two types of automation:
Automation Basics: https://www.atlassian.com/software/jira/guides/expand-jira/automation
You can do this via global rules to apply to all projects also. You'll need to be a Jira Admin/Site Admin, go to Jira Settings > System > Automation Rules (left-hand menu).
For more on using Automation For Jira see these help pages.
Hey John,
Created a new ticket for the same.
The ask is if we can create a screen where it populates the projects available in the org and on a click of a button it should be able to clone the dependent stories across projects for the EPIC [OR] If there is any app in Jira itself where in it will help creating the dependent stories at ease.
It would help if you could tell us how to raise a support ticket instead of the community ticket that way we can explain the requirement over the call in much more detail.
I am not an Atlassian employee - just another Jira user who likes to help out. :-)
I will post a response on the other post.
We have a mix of company-managed and team-managed projects and have had mixed results with the ability to add items in other projects.
Do you know what other factors can affect this ability?
Hi, you say that epics can be used to link items across multiple projects but how? I have created an Epic but when I create Jiras in different projects I cannot select the original Epic
What type of project are you using? Team-managed? Company-managed? Jira Work Management?
Ah, that would be why. Team-managed projects are completely independent of all other projects by design, so you would not be able to use Epics across those types of projects.
Hi John - I am also not able to do this in company managed projects. (when I search for epics, only those created in my project are visable), I do have the enhance my board toggle on - is that why?
Hi, I also need this functionality described at the beginning. But for me it doesn't work. I create a story in a specific project A. I want to link it to an epic that exists already in a different project B, but can only select epics that exist in my current project A. Can you please help?
Hi Katja - Welcome to the Atlassian Community!
You should always create a new question in the Community so more people will see and and can help.
Hey @John Funk, could you help us understand how we are supposed to do that? It's impossible on my side to link tickets from different Projects to one Epic...
Using next-gen projects.
Is it planned to make it available? We are handling different User Experiences across different projects, but with really high coupling which means we frequently need to impact multiple projects per Epic...
Hi John , i am using the company managed project and still can not find a way to share an epic across different projects , any idea how i can do that ? thnx
Hi Lojayna - Welcome to the Atlassian Community!
If you are on the task/story/issue, you should be able to select the value for the Epic in the Epic Link field, even if it is on a different project from the issue's project.
Hi John Thank you so much. i am learning my way around that was very useful
@John Funk Thanks for your suggestions here. I have a question related to this.
I created Epic in different project and Stories in different projects and then link the epic to these stories.
But i am not able to see epic burndown. I think, epic burndown chart will take the stories/tasks that are in the same project as epic.
What should we do to show epic burndown with the stories/tasks created in different project.
That's a good question - but I am afraid I don't know the answer to that. You should probably contact Atlassian Support about that. If you do and get an answer, please post it back here.
