Epic / child issues /externally linked issues
Menaka
Hello there , Is their a way to create report on an specific epic which can show me its child issues as well as externally linked issues ?If so , what is the JQL used ?Thanks
Madhu_RVS
June 21, 2023
Hi
@Menaka
If you are open for a mktplace solution, we have built an app for the same use case.
Issue Hierarchy Reports
Through this app you can visualize your complete hierarchy including linked issues and much more. Do Try it out.
Disclaimer : I am part of the team which developed this app
Menaka
Hi  @Madhu_RVS
Would this app be helpful to display all the linked issues that exist outside the epic from the same or a different project board along with the child issues with in the epic ?Thanks
Madhu_RVS
June 21, 2023
Hi @Menaka
Yes. The app shows the child issues of the Epic along with any linked issues which may be in a different project as well.
Do try it out.
Hannes Obweger - JXL for Jira
Hi @Menaka
if you're open to solutions from the Atlassian Marketplace, this would be easy to do in the app that my team and I are working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. It also comes with a number of advanced features, including support for (configurable) issue hierarchies. These can be modelled based on Jira's built-in parent/child relationships (like Epic/Story), and/or based on issue links.
This is how it looks in action:
JXL sheets are fundamentally "cross-project", so parent and child issues can come from different projects, too. It's also worth noting that JXL can do much more than the above: From bulk issue editing via copy/paste, to issue grouping by any issue field(s), sum-ups, and conditional formatting
Best,
Hannes
Nicolas Gondard June 21, 2023
May I suggest this JQL clause ?
("Epic Name" = yourEpicName or parentEpic = yourEpicNb)
Menaka
Have tried the JQL but wont show up epic and its child issues in the BASIC list view navigating via issues tab
