Epic issues did not link to Initiative issue
Marziah Zarazilla October 19, 2021 edited
Hi, I have followed to a T the steps needed to link epic issues to Initiative issue so as to have a holistic view Initiative -> Epic -> Story - Sub-task in Advanced Roadmap but it is not working.  Did I missed a step?
What I can see is just Initiatives as a stand alone and there is   Epic -> Story - Sub-task  which  works fine.
Marziah Zarazilla October 21, 2021 edited
Thank you Rolf.
Initiative is added to the Filter and Project.
I believe I did link the relationship between the Epic and Initiative Maybe I did it wrong.
Just in case I did it wrong , can you show me a print screen or any resource on how to do it?
Same problem as https://community.atlassian.com/t5/Jira-Software-questions/Adding-a-Parent-Link-to-an-EPIC-issue/qaq-p/1466608
Rolf Okken October 22, 2021
This is an Epic, the parent is an initiative
Select the edit button
Select the folder links
Marziah Zarazilla October 24, 2021
Thank you Rolf.
Rolf Okken October 19, 2021
  1. Check: The relation between Initiative and Epic is a Parent link. Is the link set?
  2. Check the Filter, Project or Board which fill the plan. The initiative you will display are included?
