Epics beget stories and stories beget subtasks
George Carvill
September 13, 2012
Currently we have a two-level hierarchy. I would like to see three levels:
Epics --> Stories --> Sub-Tasks.
I would like the swimlanes to support this. For example, using the Story model, a horizontal band in one color for an Epic, then multiple horizontal bands for stories beneath it, and then the sub-task cards beneath the stories.
Presumption is that an Epic could span projects, a story could not.
Lucas Molenaar
September 13, 2012
Not sure if this will work but you could try creating swimlanes based on queries and add unique labels to the epic/stories, but that will require maintanance
e.g. (type = Epic OR type = Story) AND labels in (Sprint1,Sprint2)
George Carvill
September 13, 2012
Thanks. I did, actually. But I found that the way the boards look based on queries is very different from those based on stories -- and I much prefer the story version.
George Carvill
October 23, 2012
auto-email today suggests I should do one of the following:
  • Accept an answer (click the grey check mark)
  • Answer your own question, then accept your answer (find the 'Answer my own question' link underneath your question)
  • Edit your question for clarification
  • Add a comment for more information from an existing answer
  • Close the question, if it's invalid
But nothing has changed since Sept. 14 (above).
George Carvill
October 29, 2012
Ditto today.
George Carvill
November 28, 2012
The new way of handling epics is a good start. I'd still like to see three-level swimlanes, however.
erento GmbH February 12, 2013
hi GeorgeCC, tnx - but i mean what JQL to use to group all stories belonging to an epic by swimlanes
So I have First Epic with a name Epic1 with Stories S1 and S2 and I have Second Epic with a name Epic2 with Stories SA and SB
Now in a “Work”-View I would like to see two swimlanes named Epic1 and Epic2 witch have they corresponding stories?
i.E. "Epic Link" = "EpicName2" OR "Epic Name" = "EpicName2" doesent work – any suggestions?
George Carvill
February 12, 2013
Don't know the answer to that. We don't do it that way. Maybe someone else has an idea.
hi GeorgeCC, can u pls tell how?
tia Nermin
George Carvill
February 12, 2013
George Carvill
February 5, 2013
The latest Greenhopper changes (I think) finally made this work as we wanted it.
I can now group Stories into Epics.
Peter Dittman
I've struggled with this as well - finally just gave up, attributing the challenge to the impedence between a flat issue system (JIRA) and a heirarchical need (Agile story management) (it's not unlike the problem of implemented objects on a relational database - it's just hard).
Part of the issue is JQL does not understand the heirarchy - an issue is an issue, some have different types - but issues don't contain other issues (it's not an OO-based system), you have to emulate that containment as best you can; the swimlanes doesn't appear to enable it...
just my $0.02.
Eric Sullender November 13, 2012
Apologize if my terminology is off, this is my first day with Jira/Greenhopper and I'm trying to figure out if it will work for my company.
I can manually create swimlanes based on an epic in the Scrum Board (JQL: "epic link" = OS-238). Which looks fine.. but if the Story has sub-tasks then those sub-tasks show up under "Everything Else". I would like them to either not show up or, ideally, show up under the story in the epic swimlane. Any ideas?
Ok, i figured out how to hide the sub-tasks under "Everything Else" with a quick filter: "type not in subTaskIssueTypes()"
Still would be great if Epics was a dropdown in the swimlanes selection and stories from the epic were shown with sub-stories grouped under them.
George Carvill
October 9, 2012
Received the e-mail below today. But none of the choices match. What I'd like is for Atlassian to consider this for an enhancement.
The following questions of yours are still unresolved:
* Epics beget stories and stories beget subtasks
Please consider one of the following actions:
* Accept an answer (click the grey check mark)
* Answer your own question, then accept your answer (find the 'Answer my own question' link underneath your question)
* Edit your question for clarification
* Add a comment for more information from an existing answer
* Close the question, if it's invalid
Please be a good Answers citizen!
