Error creating issue: Property 'newSubTask' not found?
Shagufta Gurmukhdas December 6, 2016
I am creating a mutable issue 'newSubTask' in my groovy script and also setting it's properties, and this is a subtask of the issue on whose On Create transition I am writing this post function. I was using ScriptRunner 4.3.13 up until now, and recently used the SR version 3.0.16 with another JIRA instance and copied this project and ran it and rceived this error of Propertyu not found. Is it due to the older version of script runner? Or is it because I might have made an error in copying? I think it is the former, though. How do I eliminate this error? (Since this JIRA instance has a lot of other projects which are using SR older version, I wouldn't want to upgrade SR and cause a havoc).
Thanos Batagiannis [Adaptavist]
December 8, 2016
Hi Shagufta,
cool. So it is
newSubTask.setAssigneeId(user.key)
//or
newSubTask.setAssignee(user.directoryUser)
regards, Thanos
Shagufta Gurmukhdas December 7, 2016
Yes this works. I'll modify my script to the older functions. Thanks a lot!!! One last thing, to assign the iissue to the current user, the line
newSubTask.setAssigneeId(user.name)
Will this remain the same? Or is the setAssigneeId function expecting something else in the older versions?
@Thanos Batagiannis [Adaptavist]
Viktor Kuzmychov
I use JIRA 6.4.7 and SR 3.1.3. For me following function works:
ApplicationUser loggedInApplicationUser = ComponentAccessor.getJiraAuthenticationContext().getUser()
IssueInputParameters issueInputParametersCreate = ComponentAccessor.issueService.newIssueInputParameters()
issueInputParametersCreate.setSkipScreenCheck(true)
issueInputParametersCreate.setIssueTypeId(ComponentAccessor.issueTypeSchemeManager.getSubTaskIssueTypesForProject(taskIssue.projectObject).find{it.name=="Atomic SubTask"}.id)
issueInputParametersCreate.setProjectId(taskIssue.projectId)
issueInputParametersCreate.setSummary(devSummary.concat(taskIssue.summary))
issueInputParametersCreate.setReporterId(taskIssue.reporterId)
IssueService.CreateValidationResult createValidationResult
createValidationResult = ComponentAccessor.issueService.validateSubTaskCreate(loggedInApplicationUser, taskIssue.id, issueInputParametersCreate)
if (createValidationResult.isValid()) {
    IssueService.IssueResult createResult = ComponentAccessor.issueService.create(loggedInApplicationUser, createValidationResult)
    if (createResult.isValid()) {
        if (log.isDebugEnabled()) log.debug logPref + "New issue: " + createResult.issue
        ComponentAccessor.subTaskManager.createSubTaskIssueLink(taskIssue, createResult.issue, loggedInApplicationUser.directoryUser)
	} else {
        log.error "Error creating new Task Planning issue"
        for (String error : createResult.getErrorCollection().getErrors().values()) log.error error
} else {
    log.error "Error validating new Task Planning issue "
    for (String error : createValidationResult.getErrorCollection().getErrors().values()) log.error error
Vineela Durbha
Hi @Viktor Kuzmychov
I am using the similar script suggested by you and I am trying to display error message on UI. But it is showing the error message twice
log.error("entrou no createValidationResult")
IssueService.IssueResult createResult = issueService.create(currentUser, createValidationResult)
if (!createResult.isValid())
log.error(createResult.getErrorCollection().getErrors())
log.error("Error while creating the issue.")
def errorCollection=createResult.getErrorCollection().getErrors().values();
for (String error: errorCollection){
log.debug("inside error collection" +createResult.getErrorCollection().getErrors().get(0))
UserMessageUtil.error("Error : "+error)
I see that loop is being is run only once. Am i doing it in the right way?
December 7, 2016
I just tested with a SR v3.1.4 the script below
Issue parentIssue = issue
if (parentIssue.isSubTask())
    return
def user = ComponentAccessor.getJiraAuthenticationContext().getUser()
def summariesList = ["summary1",
                     "summary2",
                     "summary3",
                     "summary4",
                     "summary5",
                     "summary6"]
def issueFactory = ComponentAccessor.getIssueFactory()
def subTaskManager = ComponentAccessor.getSubTaskManager()
def constantManager = ComponentAccessor.getConstantsManager()
def issueManager = ComponentAccessor.getIssueManager()
summariesList.each { subTaskSummary ->
    MutableIssue newSubTask = issueFactory.getIssue()
    newSubTask.setSummary(subTaskSummary)
    newSubTask.setParentObject(parentIssue)
    newSubTask.setProjectObject(parentIssue.getProjectObject())
    newSubTask.setIssueTypeId(constantManager.getAllIssueTypeObjects().find{
        it.getName() == "Sub-task"
    }.id)
    // Add any other fields you want for the newly created sub task
    Map<String,Object> newIssueParams = ["issue" : newSubTask] as Map<String,Object>
    issueManager.createIssueObject(user.directoryUser, newIssueParams)
    subTaskManager.createSubTaskIssueLink(parentIssue, newSubTask, user.directoryUser)
PS. You can find your JIRA logs  - application server logs.
It is after the step.
Also, there are no errors. I think in the older version of scriptrunner there isn't any way to view errors. Anyway the issue is created without any errors , but the issues i create programmatically in its postfunction aren't created.
So, you are saying, there's no difference in the syntax, and the problem is somethinf else ? okay, i'll check...
December 7, 2016
I think the reason is in the order of your post functions. You post function should be after the "Creates the issue originally." step.
I suspect the answer will be in your logs. Feel free to paste here any errors you get in your logs.
No. i create an issue by the normal procedure. and in the postfunction i create subtasks and issues automatically as in the code i have written above. but in this version of scriptrunner i am not being able to create those subtasks or issues through the same script. I click on create, fill the fields on create screen and press create. The issue is created. But the issues and subtasks which were supposed to be created automatically through the postfunction, are not created at all. so i am wondering if the syntax for creating subtasks programmatically in a groovy script was different for older versions.
December 7, 2016
Cool.
So what you use is to create subtasks and if I understand right is working fine. And your question is how to create an issue (other than a subtask) for a JIRA v.6.* right ?
It worked!! Thanks! But the subtasks/other issues are not getting created. I mean, this issue is getting created but not any other issue programmatically. Is there some other syntax for creating issues in older versions? @Thanos Batagiannis [Adaptavist]?
Oh! I'll remove it and see laugh
December 7, 2016
I afraid you have to remove it completely, even commented it will cause issues.
Alternatively, to the workaround described in the linked bug above, you can also run the script from a file.
That line is commented in my code . So it isn't executing, hence doesnt make any difference, right? @Thanos Batagiannis [Adaptavist]
December 6, 2016
Hi Shagufta,
Do you have anywhere in your script something like
log.info "Issue with summary ${newSubTask.summary} created"
There was a bug SRJIRA-544 which was fixed for the latest versions. If you cannot upgrade then a workaround is described in the issue above.
regards, Thanos
Vasiliy Zverev
December 6, 2016
I am not sure, but trouble could be here:
subTaskManager.createSubTaskIssueLink(parentIssue, newSubTask, user)
Try to replace newSubtasc with value returned by issueManager.createIssueObject(user, newIssueParams)
I'll try
This simple code works for JIRA 7.1.0 and ScriptRunner 4.3.13 . But now it is giving this error on the create issue screen itself, in the other version. (JIRA 6.4, SR 3.0.16)  @Vasiliy Zverev
the JIRA version there is 6.4 and ScripRunner is 3.0.16.
The code is as follows:
if (valueOfRType == 'someVal')
{ MutableIssue newSubTask = issueFactory.getIssue()     newSubTask.setAssigneeId(user.name)
newSubTask.setSummary('ABC')
newSubTask.description="XYZ"
newSubTask.setFixVersions(Arrays.asList(versionn))newSubTask.setProjectObject(parentIssue.getProjectObject())     newSubTask.setIssueTypeId(constantManager.getAllIssueTypeObjects().find{it.getName() == "Sub-task"}.id)
Vasiliy Zverev
December 6, 2016
Dear Shagufta, ff you use script on different JIRA instances it mean that JIRA version also changed. Also changed version of JIRA API.
Could you provide code and JIRA versions for both instances?
