Error for automation scenario
Evgenii Baulin
November 17, 2020 edited
I'm trying to create automation rule with a such content: Screenshot from 2020-11-17 16-46-09.png
Update JSON is:
"update": {
"components": [
"add": {
"name": "{{repositoryName}}"
As a result i hava an error message after triggering this scenario: Field 'components' cannot appear in both 'fields' and 'update'
What should be done to make it works?
Thanks for help
Evgenii Baulin
November 17, 2020
I have found the issue: it has no sensce to add component field by standard and custom ways. That's why `both 'fields' and 'update'` appeared.
Syed Fazeem
I am getting Invalid JSON.
Baddy
May 8, 2022
So what was done to fix the issue?
Hanna_Kukharenka
@Baddy basically deselect the field from the "Choose field to set" drop down:
Like • 12 people like this
Patrick Haley
Thank you!
Edward Santilli
February 4, 2024
Huge thank you!
