Hi @Mike my name is Habib I might have a good solution for you please accept this answer if this helped.
try {
// code that may throw an error
} catch (error) {
console.error(error);
// handle the error
2. Return appropriate error messages: When an error occurs, return an error message that is clear and informative. This will help users understand what went wrong and how to resolve the issue. For example:
catch (error) {
return {
statusCode: 500,
body: {
message: "An error occurred while processing your request. Please try again later."
3. Use HTTP status codes: When returning error messages, use appropriate HTTP status codes to indicate the type of error. For example, use a 400 status code for user errors, such as invalid input, and a 500 status code for server errors, such as database connection failures.
4. Log errors: Use a logging library or service to log errors that occur in your application. This will allow you to diagnose issues and monitor the health of your app. For example:
const logger = require("@forge/logger");try {
} catch (error) {
logger.error(error);
// handle the error
5. Test error scenarios: When testing your app, make sure to test error scenarios to ensure that your error handling is working correctly. Test scenarios such as invalid input, network failures, and server errors.
I hope this helps you.
Thank you
Habib
Help us plant more trees
