Error making an API call from the Scriptrunner console
Jon Kocen
I have a simple script  that I am running from the ScriptRunner Console. I keep getting errors that I just don't understand. I have a test account with a password - typically we use SSO but I am bypassing the SSO function by allowing calls from my Jira server to not require SSO.
I am assuming that Jira would pick up the password I am sending in -this might be crux of my problem
Any suggestions on where to look to fix this?
Simple Get call passing UID/PWD
final hostUrl = "https://myurl.com/ASDB"
def endpoint = "/rest/api/latest/issue/ASD-1193/"
def client = new RESTClient(hostUrl)
client.setHeaders([
'Accept' : ContentType.JSON,
'Authorization': "Basic ${"test:test".bytes.encodeBase64()}", 'referrer':   https://myurl.com/ASDB/'
client.handler.success = { HttpResponseDecorator response
log.warn(response.entity.content.text)
client.handler.failure = { HttpResponseDecorator response ->
// Failure can be handled here
log.warn('failed: '+endpoint+' '+response.getStatusLine())
client.get(path: endpoint,
contentType: ContentType.JSON
Error Logs
... 21 more
Caused by: java.net.SocketException: Connection reset
at java.lang.Thread.run(Thread.java:748)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
... 24 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 26 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 3 filtered
at com.atlassian.troubleshooting.thready.filter.AbstractThreadNamingFilter.doFilter(AbstractThreadNamingFilter.java:46)
... 4 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 3 filtered
at com.atlassian.ratelimiting.internal.filter.RateLimitPreAuthFilter.doFilter(RateLimitPreAuthFilter.java:71)
... 8 filtered
at com.atlassian.plugins.authentication.impl.basicauth.filter.DisableBasicAuthFilter.doFilter(DisableBasicAuthFilter.java:70)
... 5 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 19 filtered
at com.atlassian.pats.web.filter.TokenBasedAuthenticationFilter.doFilter(TokenBasedAuthenticationFilter.java:83)
... 3 filtered
at com.adaptavist.scriptrunner.jfr.servlet.FlightRecordingFilter.doFilter(FlightRecordingFilter.groovy:32)
at javax.servlet.FilterChain$doFilter.call(Unknown Source)
... 3 filtered
at com.atlassian.plugins.rest.module.servlet.RestSeraphFilter.doFilter(RestSeraphFilter.java:38)
... 16 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 17 filtered
... 3 filtered
at com.atlassian.ratelimiting.internal.filter.RateLimitFilter.doFilter(RateLimitFilter.java:73)
... 43 filtered
... 8 filtered
at com.atlassian.diagnostics.internal.platform.monitor.http.HttpRequestMonitoringFilter.doFilter(HttpRequestMonitoringFilter.java:55)
... 36 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.doFilter(RestDelegatingServletFilter.java:70)
... 1 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.doFilter(RestDelegatingServletFilter.java:160)
... 19 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
... 2 filtered
at com.onresolve.scriptrunner.runner.rest.common.UserScriptEndpoint.execFromJson(UserScriptEndpoint.groovy:82)
at com.onresolve.scriptrunner.runner.diag.DiagnosticsManagerImpl$DiagnosticsExecutionHandlerImpl.execute(DiagnosticsManagerImpl.groovy:394)
at com.onresolve.scriptrunner.runner.ScriptExecutionRecorder$withRecording.call(Unknown Source)
at com.onresolve.scriptrunner.runner.ScriptExecutionRecorder.withRecording(ScriptExecutionRecorder.groovy:13)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:130)
at org.codehaus.groovy.runtime.callsite.PogoMetaClassSite.call(PogoMetaClassSite.java:38)
at groovy.lang.MetaClassImpl.invokeMethod(MetaClassImpl.java:1035)
at org.codehaus.groovy.runtime.metaclass.ClosureMetaClass.invokeMethod(ClosureMetaClass.java:274)
at groovy.lang.MetaMethod.doMethodInvoke(MetaMethod.java:323)
at org.codehaus.groovy.reflection.CachedMethod.invoke(CachedMethod.java:107)
... 2 filtered
at com.onresolve.scriptrunner.runner.diag.DiagnosticsManagerImpl$DiagnosticsExecutionHandlerImpl$_execute_closure1.doCall(DiagnosticsManagerImpl.groovy)
at com.onresolve.scriptrunner.runner.diag.DiagnosticsManagerImpl$DiagnosticsExecutionHandlerImpl$_execute_closure1.doCall(DiagnosticsManagerImpl.groovy:397)
... 2 filtered
at com.onresolve.scriptrunner.runner.rest.common.UserScriptEndpoint$_execFromJson_closure1.doCall(UserScriptEndpoint.groovy)
at com.onresolve.scriptrunner.runner.rest.common.UserScriptEndpoint$_execFromJson_closure1.doCall(UserScriptEndpoint.groovy:91)
at com.onresolve.scriptrunner.runner.AbstractScriptRunner.runScript(AbstractScriptRunner.groovy:316)
at com.onresolve.scriptrunner.runner.AbstractScriptRunner$runScriptAndGetContext$2.callCurrent(Unknown Source)
at com.onresolve.scriptrunner.runner.AbstractScriptRunner.runScriptAndGetContext(AbstractScriptRunner.groovy:304)
at com.onresolve.scriptrunner.runner.AbstractScriptRunner$runScriptAndGetContext$3.callCurrent(Unknown Source)
at com.onresolve.scriptrunner.runner.AbstractScriptRunner.runScriptAndGetContext(AbstractScriptRunner.groovy:185)
at javax.script.ScriptEngine$eval.call(Unknown Source)
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:233)
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:155)
at org.codehaus.groovy.jsr223.GroovyScriptEngineImpl.eval(GroovyScriptEngineImpl.java:317)
at Risk.Script90.run(Script90.groovy:32)
at groovyx.net.http.RESTClient$get.call(Unknown Source)
at groovyx.net.http.RESTClient.get(RESTClient.java:119)
at groovyx.net.http.HTTPBuilder.doRequest(HTTPBuilder.java:515)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:165)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:221)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:72)
at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:835)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:481)
at org.apache.http.impl.client.DefaultRequestDirector.tryExecute(DefaultRequestDirector.java:679)
at org.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:125)
at org.apache.http.protocol.HttpRequestExecutor.doReceiveResponse(HttpRequestExecutor.java:273)
at org.apache.http.impl.conn.ManagedClientConnectionImpl.receiveResponseHeader(ManagedClientConnectionImpl.java:207)
at org.apache.http.impl.conn.DefaultClientConnection.receiveResponseHeader(DefaultClientConnection.java:257)
at org.apache.http.impl.AbstractHttpClientConnection.receiveResponseHeader(AbstractHttpClientConnection.java:294)
at org.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:259)
at org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:56)
at org.apache.http.impl.conn.DefaultHttpResponseParser.parseHead(DefaultHttpResponseParser.java:138)
at org.apache.http.impl.io.AbstractSessionInputBuffer.readLine(AbstractSessionInputBuffer.java:276)
at org.apache.http.impl.io.SocketInputBuffer.fillBuffer(SocketInputBuffer.java:82)
at org.apache.http.impl.io.AbstractSessionInputBuffer.fillBuffer(AbstractSessionInputBuffer.java:161)
at sun.security.ssl.SSLSocketImpl$AppInputStream.read(SSLSocketImpl.java:831)
at sun.security.ssl.SSLSocketImpl.access$300(SSLSocketImpl.java:72)
at sun.security.ssl.SSLSocketImpl.handleException(SSLSocketImpl.java:1303)
at sun.security.ssl.TransportContext.fatal(TransportContext.java:262)
at sun.security.ssl.TransportContext.fatal(TransportContext.java:267)
at sun.security.ssl.TransportContext.fatal(TransportContext.java:355)
at sun.security.ssl.SSLSocketOutputRecord.encodeAlert(SSLSocketOutputRecord.java:81)
at java.net.SocketOutputStream.write(SocketOutputStream.java:155)
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:111)
at java.net.SocketOutputStream.socketWrite0(Native Method)
Suppressed: java.net.SocketException: Broken pipe (Write failed)
javax.net.ssl.SSLException: Connection reset
2023-02-27 11:09:42,898-0600 http-nio-8080-exec-23 url: /ASDB/rest/scriptrunner/latest/user/exec/; user: jkocen ERROR jkocen 669x1890x1 u6zzke 156.68.7.99,10.1.3.194 /rest/scriptrunner/latest/user/exec/ [c.o.s.r.rest.common.UserScriptEndpoint] Script console script failed:
SERVER
Read the story
