Error while searching issues by a select cascade custom field
Grupo Espirita Casa do Caminho September 10, 2020
I get the attached image error when making a search using a select cascading list ("The option "nnnnn" is an invalid option in the context '' ")
JUST IN TIME: both cascade contents are VALID options, and if I make the same search using the Advanced search mode instead of Basic Mode (writting down the JQL), it works fine.
The Advanced syntax used was:
project = GECC AND issuetype = Alocação AND status = Ativa AND "Diretoria/Atividade" in cascadeOption("Administração e Finanças", Recepção)
But as my users are not familiar with Advanced Search, I need Basic mode working correctly.
Mehmet A _Bloompeak_
Hi @Grupo Espirita Casa do Caminho ,
It seems you found a bug on Jira. You can create a bug to Atlassian Support.
https://support.atlassian.com/contact
Register here ⬇️
