×Hello ladies and gentlemen,
I have a question about native Jira and creating more issue types in an expanded hierarchy. What I mean is, is it possible to create types above or below standard "Epic>Task>Subtask" issue types?
I haven't found the answer on forums or the Jira Software Cloud resources site.
Thank you
Welcome to the Community!
Plain Jira only has issue -> Sub-task. Software adds the Epic layer. For more, you will need apps or premium subscriptions - Advanced Roadmaps adds initiatives and themes above Epic, and apps like Big Picture and Easy Agile make representations of more layers. Structure is an app designed to give you complete freedom in setting up a wider hierarchy!
Thank you very much for your answer.
I am using the Structure app for a different reason. It is true that it might help me organise projects in a more hierarchical order.
Patryk
welcome to the community!
Here's another app that you might like: JXL for Jira. It's a full-fledged spreadsheet/table view on your issues that allows configuring as many hierarchy levels as you want - either based on Jira's native parent-child relationships (as discussed by Nic before), or based on issue links between issues.
Here's how a 5 level hierarchy looks in JXL:
It's worth nothing that JXL can do way more than that. E.g. you can freely configure the table to match your needs, inline-edit your issues either individually or in bulk, perform quick sorting and filtering, and much more. More info at https://jxl.app. Disclaimer: I work on JXL :))
Hope this helps,
Hannes
Thank you for your answer!
It does resamble a spreadsheet. I can imagine working on that. It can quickly bring familiarity to a recipient of working with something intuitive.
Patryk
Awesome @Patryk Potaczek - just to clarify one more point: JXL allows showing any of your fields. You can add, remove, or re-arrange them to perfectly match your use case!
This JXL give us another way to handle the Link Hierarchy
Welcome to the community !!
You can use issue links to create your own hierarchy above and below Epics or infact at any level.
To visualize the hierarchy based on the issue links, we have created an app to track the progress at each level,
Agile Tools - Epic Tree, Links Tree and Time in Status
Key features of Links Hierarchy:
Thank you for answering my trouble.
I have looked at provided pictures of the app on the marketplace. I understand that it is also flexible regarding what data it shows in columns.
I will check it out.
Patryk
