Export - Create dashboard gadget changed. Most quick gadgets don't have filter options.
Charles Liss August 18, 2023
Seem Atlassian pushed a new update to the Create dashboard gadget on filter query results.  It seems for example, I can only view the assginee in the pie chart and can't change it.  Is there is known bug or is this the way of the world?  If its the way of the world going forward this is a huge loss for advance user productivity.
Charles Liss August 21, 2023
From a list view of search results selecting Export -> Create a gadget.  In this example for Pie chart there use to be a way to configure what property to target.  This is no longer possible on this and other quick gadgets which makes for quick visualizations very difficult now.
Screen Shot 2023-08-21 at 12.44.49 PM.pngScreen Shot 2023-08-21 at 12.45.40 PM.png
August 19, 2023
Hi @Charles Liss
Would you please post an image of what you are seeing?  That may provide more context for the community to offers ideas.  Thanks!
I just did but didn't reply inline sorry.  Clicked on the wrong reply box :)
August 21, 2023
Thanks, Charles.  I have not used that feature before.
Updating my reply as I just found the suggestion to add back in the behavior you noted.  You can watch / vote for it to see progress: https://jira.atlassian.com/browse/JRACLOUD-81632
