Hi! How can I export a List or Sheet with all the projects created and currently active in my Companies Jira ?
Hi @Manuela Gomes ,
The following should work:
@Dawid Joshua _TechTime_ I used your solution and it worked - thank you!
The only thing I did differently was use https://domain.atlassian.net/rest/api/3/project/ instead of .../project/search because .../project returned the complete list of projects, whereas .../project/search returned only the first 50 projects by alphabetical order.
Everything else was spot-on though. Thank you again!!
hi, this worked great for pulling up the list of projects. One question, is there anyway to see a time stamp of last used or last time an issue was updated within the project in the results?
You can easily do that with the Better Excel Exporter app. Follow this tutorial.
(Discl. it is a paid and supported app, developed by our team.)
Hello @Aron Gombas _Midori_is it possible to export all projects with all their insights and CMDBs in one single Excel sheets with Better Excel Exporter for Jira Server ?
Not with one click.
But:
1 is the elegant solution, which should be preferred if this is something that you want export time to time repeatedly. 2 is a manual approach, it doesn't require any scripting skills, but it is more work if you have to do this again and again.
Thanks a lot @Aron Gombas _Midori_ for this detailed answer!! I'll make sure to try both solutions and see which one fits better for our need :)
I just want to collect all the project names in a file(csv/excel) is this possible in Jira. i am not seeing Add-ons menu in my Jira app. without thrid party installations software is it gettable
@Karthikeyan.Rajagopal It's not available out of the box. If you don't see the Apps menu, talk to your admin and ask them to install an app that can help you with this, like Better Excel Exporter.
Adding a comment here to highlight that @Dawid Joshua _TechTime_ solution posted on this page works! No 3rd party app needed.
Hi @Manuela Gomes
Welcome to the community!
I'm Yousef, nice to greet you, I'm Product Marketing at DEISER, a Marketplace provider.
We have a blog, where we talk about this topic, if you want, here I attach it https://blog.deiser.com/en/seven-ways-to-export-jira-issues.
I hope it will help you with your question.
If you need more information let me know and I will be happy to talk to you.
Hello @Manuela Gomes
Welcome to the community.
There is not a built-in report for getting the list of projects. You can use a third party app or you can use the Jira REST API to get that information.
