Export velocity Chart in excel/ CSV format
Anil Kumar
Any suggestion/recommendation forJira plugin that can enable exporting Jira reports like Velocity Chart in excel/ CSV format?
Nic Brough -Adaptavist-
September 17, 2021
CSV does not support charts as content, so I'm afraid your question makes no sense there.
Excel is actually much the same, but does support content that is effectively code that reads data and tells the program you read it with to display data as a diagram.
But, either way, there is no data to export that can give you a chart.  When Jira shows you a chart, it is reading the issue data (and anything else it needs), and building the charts you see from that.
You can, of course, extract the raw data that goes into generating the chart.  An export of the Jira issues can contain most of the data you need to be able to draw up a velocity chart, you'll just need to get the sprint start and end date to frame it.
Anil Kumar
Thanks Nic for reply, question was for dat export in Excel (it capture chart also)/CSV (raw data that may concern as chart/pivots post export)
Like jk likes this
September 18, 2021
Yep, to do that, run a search for the issues you want to report on, and then look to the top right for the export to CSV
FREE
