Hi team,
I need to export issues from JIRA to a CSV file whereas i don't require all the fields to come in CSV file.
Is it possible to export the issues with only desired fields into CSV?
Hi @Akil Official ,
Welcome to the community !!
Yes, you can export issues with only required fields.
4. Click on Export button and select option "Export Excel CSV (My default)" option.
File will be downloaded with only selected columns.
Hey @Rilwan Ahmed and @Mayur Jadhav Thanks for your response.
Just wanted to share with you that we have set up JIRA specific for client. I am not able to find this columns option available.
I am also JIRA Admin so can anyone help me know how to get this columns option set up? Please find below image for reference.
Hi @Akil Official ,
Click on Advanced and then make a search using JQL. If its only a single issue, then you can use Key = "EAMS-146".
Go through each steps as mentioned in my previous comment.
Hey @Rilwan Ahmed i have already set the filter. Tried it both basic way and also using Advanced option to set the filter. That advanced option is just an to set the filter, right? The screenshot shared above is post setting the filter. I am not able to find columns to set the desired fields.
I understood the steps you had mentioned but couldn't find the columns tab in my JIRA.
Change the view to list view
Hi @Akil Official ,
Please accept my first comment as answer if this resolved your issue. Users with similar query will find it useful.
Hi @Rilwan Ahmed I am getting reports with my default fields, but along with these fields, I also see "Assignee ID" and "Issue ID." I want to remove these fields by default. Is there an alternative way to do this?
Hello @Akil Official ,
Welcome to the Atlassian Community!!
Yes, you can export an issue with required fields.
Similar thread is available on Community where one of Community leader has given solution on that.
Hope this information help
Mayur
