×Hi,
I'm trying to export Jira Cloud Projects (it contain only one project) to Jira server, I know it is tricky but I also followed the instruction from Jira so I supposed it has to work! but I get the error, and yes if I check the entities.xml all the issues do not have Key
There was a problem parsing the backup XML file at /var/atlassian/application-data/jira/import/jira-export.zip: com.atlassian.jira.exception.ParseException: No 'key' field for Issue XXX.
First, the steps that I've tried from here (link)
There was a problem parsing the backup XML file at /var/atlassian/application-data/jira/import/test1.zip: Content is not allowed in prolog.
The current version of Jira is at build number '822000', but the supplied backup file was for build number '72002'.
I cannot find Jira instance with version 7.2.0, Is there anything that I've missed here ??
