Hi, I want to create a Variable by extracting a number out of a string using regex. I did not find any documentation on how to do that. Is this even possible?
Imagine
Version 5.3
I want to extract the 3 part, like
Version 5.(\d+)
But how to do that in the "Create variable" action?
Hello @KB
You should be able to use the match function with a regex against a string representation of the fields value.
Refer to:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-text-fields/#match--
This indeed worked,
This is how I extract the number and increase it by 1.
{{#=}}{{version.name.match(".*[0-9]\.(\d+).*").asNumber}} + 1{{/}}
