FORGE API JIRA difference between search in browser and resolver response
Felipe Rodriguez
July 28, 2023
Hello community,
I have doubts, when I make a query to get the issues between dates through
https://mydomain.atlassian.net/rest/api/3/search?jql=createdDate%20>%20202323-07-01%20AND%20createdDate%20<%20202023-07-30
I get the issues correctly.
But when I do it through the resolver I get all the issues, but the statement is the same.
resolver
.define('fetchIssuesByDate', async (req) => {
const
startDate = req.payload.startDate.substring(0,10);
const endDate = req.payload.endDate.substring(0, 10);
const jql = `jql=created>${startDate} AND created<=${endDate}`;
const response = await api
.asUser()
.requestJira(route`/rest/api/3/search?${jql}`);
const data = await response.json();
const issues = transformIssuesData(data);
return issues;
// aux function
function transformIssuesData(data) {
const issueKeys = [];
for (const issue of data.issues) {
issueKeys.push({
"key": issue.key,
"id": issue.id,
"timespent": issue.fields.timespent,
"created": issue.fields.created,
"summary": issue.fields.summary
return issueKeys;
Felipe Rodriguez
July 30, 2023
I found the way to search by JQL sentence in doc Jira API.
resolver.define('getIssuesAndFilterByDate', async (req) => {
const startDate = format(new Date(req.payload.startDate), 'yyyy-MM-dd');
const endDate = format(new Date(req.payload.endDate), 'yyyy-MM-dd');
const jql = `created >= "${startDate}" AND created <= "${endDate}"`;
const bodyData = {
expand: ["names", "schema"],
fields: ["summary", "status", "assignee", "timespent"],
fieldsByKeys: false,
jql: jql,
startAt: 0,
const response = await api.asUser().requestJira(route`/rest/api/3/search?$`, {
method: 'POST',
headers: {
'Accept': 'application/json',
'Content-Type': 'application/json'
body: JSON.stringify(bodyData), // Convertir el objeto en una cadena JSON
console.log(`Response: ${response.status} ${response.statusText}`);
//console.log(data);
return data;
Read the story
