As titled, I have set a new custom filed which is "Text Field (multi-line)".
According to JIRA doc, I should use "#" / "*" to display the list (JIRA Doc)
However, it failed. I can't set up the list. May I know if my syntax or the setting of the custom field is wrong?
Hi @Chan Yui Lik ,
I think you need to change the renderer of that custom field. You need to go to field configuration for that specific project and change it there.
Navigate to Project Settings -> Issues -> Fields -> Click the pencil icon (Edit) -> Find your field -> Click "Renderers" on the right and change the renderer to Wiki Style Renderer.
Thank you so much!! It works!!
