I have a requirement where I need to fetch jira teams(with their ids), update those teams and if required even create a new team via rest APIs.
By teams I mean
I checked a few months prior, there wasn't any such API. However, there was some Atlassian conference recently, I did check the releases briefly, however still wanted to confirm whether there's any support for such API .
Any help is much appreciated!
Hi @Disha Trivedi ,
As far as I know, things are unchanged: There still isn't an official API available.
However @Darryl Lee found an undocumented endpoint that might be what you are after. You can check this post for more info: https://community.atlassian.com/t5/Jira-Software-questions/How-to-get-all-Teams-in-JIRA-via-the-cloud-rest-api/qaq-p/2347367#M264437
Keep in mind though, that using unofficial APIs is certainly not supported and considered hacking by many.
Hope that helps,
Oliver
the endpoint mentioned - does not allow for listing all teams within org, unfortunately. there is a way to do it via the graphql, since no official rest API endpoint available still
Hello @Disha Trivedi , Hello @Oliver Siebenmarck _Polymetis Apps_ ,
It looks like, there is an API now: https://developer.atlassian.com/platform/teams/rest/v1/api-group-teams-members-public-api/#api-gateway-api-public-teams-v1-org-orgid-teams-teamid-members-post
Just got this from the support. And it is a bit hidden on the https://developers.atlassian.com all the way at the bottom right.
Hope this helps.
Best regards!
