Filter epics from other projects on the same board
corinne.sabom October 14, 2020
I have a questions when it comes to the filter for scrum board in Jira
We have three projects running and in some way they relates to eachother and this is why we have set-up a filter where it will show the Epics from the other project on the same board
Now my questions is, can i set this at automatically if an Epic has the same name?
For now I have to add every Epic into the filter manually and by time the Epics for the different project are going to increase so to be able to do a setting by default woyuld be great......
Thank you in advance
Cheers
Guilhem Dupuy
October 14, 2020
Hello Corinne,
I think you can definitely improve your filter. I'm not sure I completely understood your need, if my answer doesn't answer your question please specify how your want to filters your Epics.
From what I understood, you want to display on your board every Epic coming from one of your 3 project. The following filter will answer this issue :
  • issuetype = Epic AND project IN ("Name of Project 1","Name of Project 2","Name of Project 3")
Let me know if it helped or not,
Guilhem
