Dear All, is there a possibility to choose the option "IS NOT" in the filters in PLANS?
I am talking about the Filter menü in the timeline view of PLANS.
For Example if I would like to filter the components, I often I one componente I do not want to show, but all others shall appear. At the moment I would need to checkmark all and uncheck the only one not to be shown. That is quie unhandy :-(.
Thanks for any support here.
Hi @Dirk Höhne welcome to the Atlassian Community!
Although I understand your question, this is currently not possible. You'll need to select all (individually) and then unselect the component you would like to exclude.
Thanks for the answer! What if we have items without components? I'm not seeing "empty" as an option to select.
Create ghibli art style of this photo
