Finalized tasks disappear automatically.
Pablo Diorio July 19, 2022
I have 3 cards into Jira Software....
To do
In progress
Finalized.
In finalizad card, I often lose the task finished....  And I cannot find them anywhere......
3 votes
Walter Buggenhout
Hi @Pablo Diorio and welcome to the Community!
It is a bit difficult to see what you mean, here. I can imagine that your issues disappear from a board, which is common if a status is not mapped correctly to the column of a board.
If that is the issue you're experiencing, you can read more about boards in this article.
Also, you can always find your issues in Jira by searching for them. If you want to find issues with status Finalized, navigate to Filters -> Advanced search and enter the following:
status = Finalized
That will return a list of all issues having that status.
Hope this helps!
Pablo Diorio July 19, 2022 edited
WhatsApp Image 2022-07-19 at 2.26.48 PM.jpeg WhatsApp Image 2022-07-19 at 2.27.12 PM.jpeg Thanks,
here you can see the project without finalized items, but the filters shows a lot of them... so why I cant see??
Walter Buggenhout
Aha,
thanks for the screenshots, @Pablo Diorio. This is a Jira Work Management board. Your issues in the done column only remain visible there for 14 days after they were closed. After that, they sneakily disappear indeed:
Screenshot 2022-07-19 at 19.38.58.png You can still view them from the list, timeline and calendar views. Check out the docunenntation for a bit more background.
Pablo Diorio July 22, 2022
Thanks for your answer!!
It was helpfull.
FREE
Register today
