I am working on creating an automated sub-task dependant on entry of a custom field. I have got this working and I am looking to send a notification to the assignee (Custom field from parent) on sub task creation. I have tried a few things, I have created a new notification scheme specifically for this and tried it using Issue Created and Issue Assigned independently. Around 50% of tests are sending notifications to users but some users are not receiving anything. Is there a setting higher than this that the user could potentially select that is stopping these being sent? I have looked at user settings to ensure they have receive notification on, but still issues.
How are you implementing this? This could be a rule execution-timing issue.
I tried the notification with an automation rule and it seemed to work okay. Here is what I did:
As you are also automating creation of the sub-task, consider doing the create and notify in 2 rules (setting the notify rule's option to allow first rule to trigger it). Or, you could create the sub-task and re-fetch before trying to send the notification.
Best regards,
Register today
