Fix Versions Approvers option
Donny Gison
Not sure if this feature has been here for some time but I only recently noticed the "Approvers" option in Fix Versions.
I tried it, but it seem to not send any notification?  Has anyone tried it? Thinking of using this for release management approvals. THanks.
yurikudin
Hi @Donny Gison,
It is not exactly what you are looking for but I believe that one of our apps might be helpful for your case: Release management  (DC Version)
In the application you could be able to define a release workflow:
for each workflow step, we can define approvers (in addition to other validation rules):
Also, various notification rules could be configured by using release automation inside the app. The notification could be sent by release data change, status change etc.
The messages could be sent via email, Slack, MS Teams.
Feel free to schedule a free demo if you find it interesting.
Yuri
Mohamed Adel
November 28, 2023
Hi @Donny Gison
The feature already there but unfortunately you can't block the release on the approvers actions or sending notification to them
you can check details about this feature here Progressive Delivery capabilities in Jira Software
Register now
