Hi, am preparing for ACP-600 and came across a below question:
Your development team has just released their first version of a GPS tracker yesterday. The next product release is not due for another 3 months.
Which two JQL queries, when executed today, will list all features shipped in the 1.0 version? (Choose two.)
A. project = GPS AND issuetype Feature AND fixVersion = released()
B. project = GPS AND type = Feature AND fixVersion in (1.0)
C. project = GPS AND issuetype = Feature AND fixVersion(s) IS NOT EMPTY
D. project = GPS AND type = Feature AND fixVersion in releasedVersions()
E. project = GPS AND type = Feature AND fixVersion(s) = “1.0”
F. project = GPS AND issuetype = Feature AND fixVersion in 1.0
I believe the correct answer is D.
Also, I doubt whether fixVersion(s) is a valid syntax to be used in JQL?
Could you please clarify this.
Hi @Thilaga Raguram Welcome to Atlassian Community!
Let's consider all the possibilities:
Best regards,
Piotr
No, this is wrong. You have not read the question properly and your statement about requiring brackets is incorrect.
@Nic Brough -Adaptavist- tell me where I am wrong?
1. From question:
Your development team has just released their first version of a GPS tracker yesterday. (...) Which two JQL queries, when executed today, will list all features shipped in the 1.0 version?
So there is only 1 released version, and when we will run this query today we will receive only issues from 1.0 version.
2. From documentation:
The "IN" operator is used to search for issues where the value of the specified field is one of multiple specified values. The values are specified as a comma-delimited list, surrounded by parentheses.
3. I even created demo project with such configuration:
Piotr
fixVersion in 1.0 works fine for me (as long as I have a version called 1.0 somewhere), and answer D is incorrect because it does not specify version 1.0
The question does say "just released their first version", but D is wrong at the instant they release another version, which could be done before the questioner asks the question.
If your answers are correct, then the question is poorly written - all answers should be inarguable, and these are not.
In question you have information that there will be no release for another 3 months so dev team couldn't at the instant release another version.
But there is one ambiguity in this question. In sentence "Your development team has just released their first version" there is no information about the name of that version and of course it could be named for example "v1" not "1.0". I agree that question and all answers should be inarguable!
BTW. In terms of IN operator, I have just verified it in Cloud and Server 8.12 and on both IN operator required ( ).
The version I'm on "in" needs no (), and the fact that releasedVersion() will not show you only the version you just released means the answers are arguable and hence incorrect.
B is in fact the only inarguable answer that is correct. (F is the other correct answer, but only for some versions of Jira, which hence breaks the question)
I really don't like that bad questions like this have been published or used in the exams. It's exactly this sort of thing we were taught not to do when we started writing the exams, it seems more recent writers are failing.
Thanks Piotr for detailed demo!
I also guessed B & D as the right answers. However, was having doubt in B.
I read in an Atlassian confluence page as below:
fixVersion in ("3.14", "4.2")
(Note that full-stops are reserved characters, so they need to be surrounded by quote-marks.)Since there were no quote marks I thought it might be wrong. If there are multiple values then it should be surrounded by quotes, and in our case, the IN operator has only one value, hence did it pass through without quotes?
I verified and both the Cloud and Server (8.12.2) versions do not require from me quote-marks in this case, even when I provide a list of versions. I assume there may be an error in this part of documentation.
Naturally, if there is a version name which include comma, for example, "v1,0", quote-marks will be needed.
You are right about fixversion(s) but you need to read the question properly. Note that it asks for a specific version, not all the released versions. Also that it asks for you to select two of the 6.
