Flow metrics plugin
Monica Gupta
Are there any plugins or other means to measure flow metrics? Flow velocity, Flow time, Flow efficiency and Flow Load?
Aron Gombas _Midori_
May 9, 2023
Ditte Simard
May 10, 2023
My Jira instance has ActionableAgile installed and it has the following metrics in its "Key Flow Data" area:
- Cycle Time Scatterplot
- Aging Work in Progress
- WIP Run Chart
- Throughput Run Chart
It also has Cumulative Flow Diagram and Flow Efficiency.
I hope this helps!
Like • 2 people like this
Peter Van de Voorde
May 10, 2023
Hi Monica,
At Umano we have a tool called TeamX that integrates with Jira (among other sources) and gives you over 20+ Agile metrics that will help you track your team's general performance.
I don't know if that is what you're looking for but I just wanted to give you the information.
You can check it our here: https://umano.tech
I hope you'll find the perfect tool for your needs.
Peter
