Hi @sai reddy ,
if you want to set permission on a specific field, such as label, using builitin capabilities you can :
Pro : no apps required
Cons : you can't manage that field at creation time
Hope this helps,
Fabio
You would need an addon application in order to set permissions on fields. Check the marketplace for options.
None that I am aware of. You might consider the idea from Fabio though I expect it may no meet your requirements.
Read the story
