Generic Rules for all next gen projects
Mark Grenville August 14, 2020
Is it possible to add context fields and other project customisations to all next gen projects?
I work with multiple clients and I want to have each of the projects follow the same structure. If there is some kind of automation plugin that will sync this up then that is also fine.
Ste Wright
August 15, 2020 edited
Hi @Mark Grenville
Not natively - each Next-Gen project is entirely independent and you need to create fields, etc in each project individually.
There are a few suggestions you can vote/follow for this, such as JSWCLOUD-17430
Or to see all current suggestions for Next-Gen - which you can search to see if one closely matches your use-case - view JSWCLOUD-17392.
If there isn't one, I would create one so Atlassian are aware of your need!
Ste
FREE
